Téma: Eminence Omega Pro 18A
Dobrý den, chtel bych se zeptat do jaké ozvucnice by jste dali tento reproduktor.
Parametry:
Nominal Impedance* 8 ohms
Power Rating
Watts 800W
Music Program 1600W
Resonance 25Hz
Usable Frequency Range 40Hz-800Hz
Sensitivity 97
Magnet Weight 109 oz.
Gap Height 0.375", 9.53mm
Voice Coil Diameter 4", 101.6mm
THIELE & SMALL PARAMETERS
Resonant Frequency (fs) 25Hz
DC Resistance (Re) 5.20
Coil Inductance (Le) 1.67mH
Mechanical Q (Qms) 8.18
Electromagnetic Q (Qes) 0.32
Total Q (Qts) 0.31
Compliance Equivalent Volume (Vas) 548.7 liters / 19.4 cu.ft.
Peak Diaphragm Displacement Volume (Vd) 556cc
Mechanical Compliance of Suspension (Cms) 0.29mm/N
BL Product (BL) 18.8 T-M
Diaphram Mass inc. Airload (Mms) 138 grams
Efficiency Bandwidth Product (EBP) 79
Maximum Linear Excursion (Xmax) 4.8mm
Surface Area of Cone (Sd) 1159.0 cm2
Maximum Mechanical Limit (Xlim) 16.0mm
