Téma: Ozvučnice pro Magnat SUB300 Supreme
poradi mi nekdo jakou ozvucnici na tento subwoofer?Mam tu vypočítanou bassreflexovou ale nejak se mi to nezda halavne delka natrubku viz nize. Moc prosim o radu. Diky
Vb = 37,71l
V(total) = 45,15l
Fb = 35,99Hz
QL = 6,943
F3 = 50,64 Hz
Fill = minimal
Dv = 100mm
Lv = 402,4mm
Parametry subwooferu
Fs = 30Hz
Qms = 4,3
Vas = 110l
Cms = 0,138 mm/N
Mms = 203,9g
Rms = 8,94 kg/s
Xmax = 8 mm
Xmech = 12 mm
P-Dia = 308,8 mm
Sd = 749,2sq.cm
P-Vd = 0,599 l
Qes = 0,31
Re = 3,4 Ohm
Le = 0,186 mH
Z = 4 Ohm
BL = 20,53 Tm
Pe = 300 wats
Qts = 0,29
no = 0,924%
1-W SPL = 91,86dB
2,83-V SPL = 95,57 dB
