24. 8. 2020, 9:53
| úprava 24. 8. 2020, 9:54
používám izolovaný zdroje, třeba B0505s, nebo B0512s, 1W výkonu, a ty čísla jsou podle napětí vstup / výstup. Na ali se to koupí po dolaru, a není pak v zařízení hromada traf.
Merač elektroniek
24. 8. 2020, 9:53
24. 8. 2020, 10:16
| úprava 24. 8. 2020, 10:18
aha tak taka moznost mi vobec nenapadla. A ten menic ma normalne galvanicky oddeleny vstup / vystup? ja sa toho trochu bojim z dovodu ze to chcem na ampermeter ktory moze byt aj na +400V potenciale.
EDIT: aha tak uz som nasiel v datasheete pisu 1kV isolation, takze to by pouzit slo. Super, dik za skvely tip!
2. 9. 2020, 10:16
Tohle mi dneska přišlo mailem:
Kód: The development of the uTracer6 has made good progress the past months. At the moment the first ten uTracer6 kits have been shipped to selected beta testers all over the world, and we are awaiting their experiences!
For the time being I have added a new section to the uTracer6 weblog titled "The uTracer6 on the bench." In it you will find more experiences with the uTracer6, some problems and mitigations.
Assuming we encounter no major roadblocks or problems, it is our plan to have the uTracer6 kits available for sale mid-November.
Additionally, I would like to point you to the "load line calculator." A very useful tool made by Arthur Lesuisse. It takes a uTracer data file and plots the curves together with a load line and some important circuit parameters! Check it out here!
Finally, stay safe and best regards,
Ronald & Marie-JoséTakže někdy v listopadu bude snad k dispozii.
4. 9. 2020, 19:51
| úprava 4. 9. 2020, 19:57
utracer je urcite super, dik za cerstve info.
Ten ale nechcem, teda cenovo ani kvalitativne by som nevyuzil jeho potencial, a mam inu predstavu, staci mi nejaky old-school merak z matrosu co dom dal to daleko prekroci moje meracie potreby Digi lacne meraciky z ciny uz mam doma a meraju pre moje potreby super. Dokonca aj AC mA meter, uz len spravim nejaku jednoduchu dosku na ktoru to vsetko napcham a bude hotovo, uz mam vyhliadnuty aj stary hlinikovy kufrik do ktoreho sa to snad vsetko vojde. Nevedel som cim uchladim mosfety ale nakoniec v pivnici som objavil stary intel chladic tak uz mam aj chladenie mosfetov vyriesene aspon zuzitkujem elektro-bordel co mi bolo luto vyhodit ![]() uz mam finalnu schemu, len dokoncit DPSku...
14. 9. 2020, 12:41
| úprava 14. 9. 2020, 12:57
DPS mam hotovu, uz len dokablovat zvysok... Len nejako musim este vystuzit kufrik co chcem pouzit ako obal, je to dost tenky papundekel snad 2-3mm preklizka s hlinikovou foliou alebo co, tak to zrejme podlepim hrubsou doskou a hranoceky v rohoch aby to bolo odolnejsie a zhora panel kde budu meraky/patice/tocitka.
Takto vyzera DPS, mosfety som nakoniec pouzil IRFPC50 s keramickymi podlozkami: ![]() tu je DPSka v kufriku cca 21x31cm, este tam musim niekam vtesnat trafo a meraciky ale snad by to malo vsetko vojst:
14. 9. 2020, 20:00
Pekny
Tos ty fety brousil ci proc jsou medene ? Kdyz na to nakonec prdnes keramiku Ale tipuju zes puvodne planoval dotyk rovnou toho medenyho stredu intel chladice a nakonec si rozmyslel mit 500V na celym chladici
14. 9. 2020, 20:03
pěkný. Jak moc ty fety topí?
14. 9. 2020, 20:39
DJ_Rix ano presne si to vsetko uhadol
a tiez som potom zistil ze intel chladic potrebuje cca 7mm puzdro, a fety maju 5mm a potreboval som tam cosi dat, podkladat som to vela nechcel tak mi tam akurat dobre padli tie 1,5mm keramiky a tiez tych 500V ako pises...rvx73 este neviem, zatial som to neozivoval, musim este nakablovat potenciometre a na stole ala vrabcie hniezdo to robit nechcem, az budem mat panel tak potom, inak by som to musel cele robit 2x. Najvacsi odber/teplo ocakavam pri testovani EL34/KT88 kde su udane char. hodnoty pri 250V a celkom velkom prude, 100-140mA, kedze na zdroji bude 450V tak to bude ubytok asi 30W. Este neviem ale ako si poradi s teplom ten malicky chladic, on na fotke vyzera masivne ale je dost maly obzvlast ked bude v uzavretom priestore, mozno budem musiet dorobit nejaky vetraci otvor aby sa to neupieklo, dam vediet az to ozivim.
15. 9. 2020, 11:29
Takhle uzavřeny se ti to těžko uchladí. Kdyby ten větrák foukal dírou o průměru alespoň toho větráku teplý vzduch ven, bylo by to něco jiného.
19. 10. 2020, 14:00
20. 10. 2020, 6:05
Moc hezké.
23. 10. 2020, 9:48
| úprava 23. 10. 2020, 9:51
Podarilo sa mi to po veceroch nakablovat a je to funkcne! Sice to vyzera hrozne ako vrabcie hniezdo a ani stahovacie pasiky vela nezachranili, ale bolo to dost komplikovane prekablovat vsetko so vsetkym aby to fungovalo ako ma. Aj ked to z fotky vyzera ako velka splet su tam 3 zvazky kablov k panelu. Este mi chyba vetracia mriezka, ktoru neviem kedy zozeniem kedze obchody su zavrete tak uvidim... najhorsia blbost bola intel vetrak, na nizkych otackach dost vrci a drevena krabica funguje ako ozvucnica pre to vrcanie
mozno ho uplne vypnem a bude sa zapinat len pri vysokej teplote. ![]() Natocim video ako to mera a hodim sem neskor link
23. 10. 2020, 17:14
Super, vypadá to dobře. Na to, jak je to zakáblovaný bych se zas tak nedíval, takhle vypadaly i ty fabrický měřáky. Ono to moc líp ani udělat nejde. Celkově se mi ta myšlenka vestavět to do toho kufru moc líbí !
24. 10. 2020, 14:20
24. 10. 2020, 22:43
pekny...ses borec!
27. 3. 2021, 12:08
| úprava 27. 3. 2021, 14:42
Trochu ozivim temu. Planoval som zbastlit nieco ako Wili, ale pritrafilo sa nieco viac sofistikovanejsie. Digitalny pulzny merac elektroniek, ktory ponuka Alain. Kupil som tento kit:
https://www.radioelec.com/kit-lampemetre...-1512.html Najlacnejsi kit (za 85e) nema napatie pre G2 (meria len triody) a tento stredny ho uz ma, ale obsahuje prepinac na zobrazenie napatia Anoda/G2 na lcd, co vobec nevadi. Ten najdrahsi ma uz vsetky 4 udaje na lcd. Alain odpoveda do par hodin a da sa kupit aj neuplny kit. Napr. ja som ho zobral bez 9V spinaneho zdroja (tj -25e) za 136e aj s postovnym. Cely kit je slusne osadeny (rubicon, kme atd), lcd ma biely, alebo modry podsvit. Posta je 16e, platba cez paypal. Anodove napatie je nastavitelne v rozsahu do 450V, G2 do 350V, predpatie G1 -100 do 0V, merany prud az do 340ma. Urcite to nie je laboratorny pristroj, ale na zakladne meranie bohato postacuje. Ale hlavne to netopi, je to male a lahke. Meranie prebieha pulzne (PIC), tj pulzy po 800 µSekund a meranie 2x za sekundu. (v tolerancii +/- 5%.) Kit je uz prednastaveny s navodom na CD, ale mailom na dotaz mi poslal schemu a postup rekalibracie. Strmost sa meria zdlhavo, treba znizit predpatie o 1V co je velmi nekomfortne. Zdroj +1V, ktory sa bude pripajat cez vypinac je v rieseni, ale mozno to pojde aj dalsim potenciometrom v serii cez prepinac, ktorym sa nastavi rozdiel 1V. Kit mam zatial v papierovej krabici a patice su na krokodilky. Na napajanie kitu staci lubovolny zdoj 6,5-8V AC, alebo 9-12V DC (cca 1 - 1,5A). Na zeravenie pouzivam spinany zdroj 40v/1A s 10A stepdown convertorom 2-36V aj obmedzenim prudu. Cakam na panel bez eloxu (56e s postou) a bude treba dorobit bizuteriu. Mam k tomu hlinikovy kufrik, nejake meraciky na zeravenie (napatie-prud). Kablovanie bude riesene cez bananiky (piny 1-9) a systemy cez prepinac A1/A2. Dalej ponuka aj tracer za 75e: https://www.radioelec.com/module-lampeme...-2095.html Za tie peniaze je to naozaj celkom slusne.
27. 3. 2021, 12:47
Wili: šikovnej kufřík. A i video je dobře urobené
27. 3. 2021, 13:53
rvx73 dik
nabuduce by som to robil ale inak, kratsie a informativnejsie, no ale na prve video... ![]() derick utracer a podobne merace...., to je uplne ina kategoria pristroja, ma to svoje vyhody a netvrdim ze to nie je super vec ma to svoje vyhody. Moja osobna skusenosti ale vravi ze elektronka sa sprava inak pri impulznom rezime ako pri trvalom zatazeni. Mozno kvoli inej teplote anody/katody? bolo by zaujimave ak by to dokazalo merat impulzne ale az po tom co to predpecie nvutorne systemy nejakym vyssim prudom
27. 3. 2021, 14:08
| úprava 27. 3. 2021, 19:13
Povodne som mal ist do tvojho riesenia, ale odradzalo ma to chladenie v zdroji. Chcel som nieco menej topiace a bez tazkeho trafa na zakazku. Vobec netvrdim ze pulzne meranie je lepsie, ale kazde riesenie ma svoje vyhody aj nevyhody. Je vsak tiez celkom otazne ci aj "tvrdy rezim" dokaze odhalit lampu, ktora po 5-10 minutach straca dych.
Mam stovky zmeranych lamp u znameho na BM215-tke a merania prakticky sedia. (teda s opakujucou sa odchylkou) Pri minimalnych prudoch na triodach (napr ECC83) podla mojich merani jeho BM-ko nadsadzuje (o cca 0,2 ma) a pri pentodach zas ubera zopar ma (asi 10%). V kazdom pripade je pre mna komfortnejsie mat mensi, lahsi a netopiaci pristroj, ktory je uz nastaveny a odskusany. Alain to predava cca 5 rokov a stale jemne upgraduje. Chladice na fetoch sa mi nepacia, tazke trafo tiez nie je zadarmo, tak som to skusil inak. V kazdom pripade to mas urobene velmi pekne. Aj tie meraciky mas vacsie, co povazujem za lepsie ako jeden maly integrovany.
27. 3. 2021, 19:19
| úprava 29. 3. 2021, 11:58
Pulzny merac si lampu len trochu “onucha” a nijako jej neublizi. (toto zariadenie je vraj blbuvzdorne.) Ak aj po zmerani pulznym testerom budu jedna-dve zo 100ks vadne (ked boli zmerane ako dobre), tak sa nic nedeje. Stale mam velmi slusny prehlad o tom co vlastne mam v zbierke a meranie si mozem kedykolvek zopakovat.
Ten najlacnejsi kit dokonca pracuje aj z baterie a ked si z nej poriesite aj zeravenie, tak mate ultra mobilny merac elektronok. (nudzovo aj na pentody v triodovom rezime.) Pre pripady, ked si idete osobne po nejake lampy v nezistenom stave. Otazka do plena. Ma niekto urobeny nejaky sumar zvukovych lamp s nastaveniami napati a hodnotami prudov? Aby som stale nehrabal do BM-kovych kariet je to lepsie mat na jednej-dvoch stranach A4 a dat si to vylaminovat. Inak zapadne testery pouzivaju u niektorych lamp ine hodnoty napati a prudov ako nase BM-ko. |
