15. 3. 2012, 12:25
Nazdar borci, chcem sa pustiť do stavby subu s reprom monacor SP-252c a rád by som vedel aký objem,rozmery ozvučnice. Preferoval by som closed.Mám 18mm drevotriesku. Miestnosť je malá cca 4x3m.
Parametre:
[spoiler]
Impedance (Z) 4Ω
Frequency range 40-3,500Hz
Resonant frequency (fs) 35Hz
Crossover frequency (12dB/oct.) (fmax) 2,000Hz
Peak rating 350W
Power rating 100WRMS
SPL (1W/1m) 93dB
Cms suspension compliance 0.55mm/N
Mms moving mass 38g
Qms mech. Q factor 3.15
Qes electrical Q factor 0.47
Qts total Q factor 0.41
Compl. equiv. vol. (Vas) 96 l
DC resistance (Re) 3.7Ω
Voice coil ind. (1kHz) (Le) 0.4mH
Voice coil diameter 39mm
Voice coil former aluminium
Air gap height 5mm
Force factor WxL 8.08Tm
Eff. cone area (Sd) 353cm2
Magnet diameter 125mm
Magnet weight 850g
Mounting cutout Ø 231mm
Mounting depth 110mm
Dimensions Ø 255mm
Weight 2.1kg [/spoiler]
Vďaka
Parametre:
[spoiler]
Impedance (Z) 4Ω
Peak rating 350W
SPL (1W/1m) 93dB
Mms moving mass 38g
Air gap height 5mm
Magnet weight 850g
Dimensions Ø 255mm
Vďaka
podpoř provoz fóra
