TS parametry reproduktorů TVM (podle výrobce)
Pro usnadnění vyhledávání použijte klávesovou zkratku Ctrl+F.
10cm / 4"
Citace:ARN-100-10/4
Sd: 46.6 cm2, fs: 71 Hz, Re: 3.76 Ohm, Qms: 1.99, Qes: 0.65, Qts: 0.49, Le: 0.14 mH,
Vas: 4.9 l, Mms: 3.1 g, Cms: 1.61 mm/N, Bl: 2.84 N/A, Xmax: 0.5 mm
ARN-100-10/8
Sd: 46.6 cm2, fs: 73.8 Hz, Re: 7.36 Ohm, Qms: 1.8, Qes: 0.77, Qts: 0.54, Le: 0.23 mH,
Vas: 4.5 l, Mms: 3.2 g, Cms: 1.48 mm/N, Bl: 3.75 N/A, Xmax: 0.5 mm
ARN-100-60/4
Sd: 46.6 cm2, fs: 71.9 Hz, Re: 3.63 Ohm, Qms: 2.44, Qes: 0.83, Qts: 0.62, Le: 0.13 mH,
Vas: 4.7 l, Mms: 3.2 g, Cms: 1.55 mm/N, Bl: 2.5 N/A, Xmax: 0.5 mm
ARN-100-60/8
Sd: 46.6 cm2, fs: 71.1 Hz, Re: 7.45 Ohm, Qms: 1.97, Qes: 0.93, Qts: 0.63, Le: 0.21 mH,
Vas: 5.1 l, Mms: 3 g, Cms: 1.66 mm/N, Bl: 3.29 N/A, Xmax: 0.5 mm
ARN-116-10/4
Sd: 46.6 cm2, fs: 69.5 Hz, Re: 3.62 Ohm, Qms: 2.27, Qes: 0.57, Qts: 0.46, Le: 0.18 mH,
Vas: 4.5 l, Mms: 3.6 g, Cms: 1.48 mm/N, Bl: 3.14 N/A, Xmax: 2.9 mm
ARN-116-10/8
Sd: 46.6 cm2, fs: 70.1 Hz, Re: 7.62 Ohm, Qms: 2.24, Qes: 0.7, Qts: 0.53, Le: 0.3 mH,
Vas: 4.8 l, Mms: 3.3 g, Cms: 1.58 mm/N, Bl: 3.97 N/A, Xmax: 2.9 mm
ARN-116-60/4
Sd: 46.6 cm2, fs: 67.3 Hz, Re: 3.64 Ohm, Qms: 2.24, Qes: 0.76, Qts: 0.57, Le: 0.17 mH,
Vas: 5.3 l, Mms: 3.2 g, Cms: 1.74 mm/N, Bl: 2.55 N/A, Xmax: 2.9 mm
ARN-116-60/8
Sd: 46.6 cm2, fs: 67.2 Hz, Re: 7.5 Ohm, Qms: 2.59, Qes: 0.89, Qts: 0.66, Le: 0.3 mH,
Vas: 5.1 l, Mms: 3.3 g, Cms: 1.68 mm/N, Bl: 3.45 N/A, Xmax: 2.9 mm
13cm / 5"
Citace:ARN-150-03/4
Sd: 72.4 cm2, fs: 50.5 Hz, Re: 3.92 Ohm, Qms: 2.16, Qes: 0.44, Qts: 0.36, Le: 0.38 mH,
Vas: 8.2 l, Mms: 8.9 g, Cms: 1.12 mm/N, Bl: 5.03 N/A, Xmax: 8.5 mm
ARN-150-03/8
Sd: 72.4 cm2, fs: 51 Hz, Re: 7.75 Ohm, Qms: 2.25, Qes: 0.55, Qts: 0.44, Le: 0.59 mH,
Vas: 8.1 l, Mms: 8.9 g, Cms: 1.1 mm/N, Bl: 6.33 N/A, Xmax: 8.5 mm
ARN-150-05/4
Sd: 72.4 cm2, fs: 45.2 Hz, Re: 3.89 Ohm, Qms: 2.25, Qes: 0.36, Qts: 0.31, Le: 0.37 mH,
Vas: 10.5 l, Mms: 8.7 g, Cms: 1.43 mm/N, Bl: 5.18 N/A, Xmax: 8.5 mm
ARN-150-05/8
Sd: 72.4 cm2, fs: 50.7 Hz, Re: 7.65 Ohm, Qms: 2.35, Qes: 0.53, Qts: 0.44, Le: 0.49 mH,
Vas: 8.5 l, Mms: 8.5 g, Cms: 1.16 mm/N, Bl: 6.24 N/A, Xmax: 8.5 mm
ARN-130-02/4
Sd: 72.4 cm2, fs: 53.3 Hz, Re: 4.01 Ohm, Qms: 1.65, Qes: 0.43, Qts: 0.34, Le: 0.39 mH,
Vas: 8.8 l, Mms: 7.5 g, Cms: 1.2 mm/N, Bl: 4.82 N/A, Xmax: 8.5 mm
ARN-130-02/8
Sd: 72.4 cm2, fs: 49.2 Hz, Re: 7.79 Ohm, Qms: 2.25, Qes: 0.48, Qts: 0.4, Le: 0.57 mH,
Vas: 11.2 l, Mms: 6.9 g, Cms: 1.52 mm/N, Bl: 5.85 N/A, Xmax: 8.5 mm
ARN-130-69/8
Sd: 72.4 cm2, fs: 64.4 Hz, Re: 7.16 Ohm, Qms: 3.02, Qes: 1.8, Qts: 1.13, Le: 0.18 mH,
Vas: 7.7 l, Mms: 5.8 g, Cms: 1.05 mm/N, Bl: 3.05 N/A, Xmax: 0.4 mm
ARN-150-73/8
Sd: 72.4 cm2, fs: 51 Hz, Re: 7.77 Ohm, Qms: 2.12, Qes: 0.57, Qts: 0.45, Le: 0.56 mH,
Vas: 8.6 l, Mms: 8.4 g, Cms: 1.16 mm/N, Bl: 6.05 N/A, Xmax: 8.5 mm
ARN-130-60/4
Sd: 72.4 cm2, fs: 51.1 Hz, Re: 3.48 Ohm, Qms: 1.92, Qes: 0.73, Qts: 0.53, Le: 0.13 mH,
Vas: 12.4 l, Mms: 5.8 g, Cms: 1.69 mm/N, Bl: 2.97 N/A, Xmax: 0.7 mm
ARN-130-60/8
Sd: 72.4 cm2, fs: 60.5 Hz, Re: 6.33 Ohm, Qms: 1.7, Qes: 0.96, Qts: 0.61, Le: 0.2 mH,
Vas: 8.9 l, Mms: 5.7 g, Cms: 1.21 mm/N, Bl: 3.79 N/A, Xmax: 1 mm
ARN-150-60/4
Sd: 72.4 cm2, fs: 54.6 Hz, Re: 3.49 Ohm, Qms: 1.72, Qes: 0.73, Qts: 0.51, Le: 0.13 mH,
Vas: 11.4 l, Mms: 5.5 g, Cms: 1.54 mm/N, Bl: 3.01 N/A, Xmax: 0.7 mm
ARN-150-60/8
Sd: 72.4 cm2, fs: 66 Hz, Re: 6.41 Ohm, Qms: 1.4, Qes: 0.87, Qts: 0.54, Le: 0.25 mH,
Vas: 8.6 l, Mms: 5 g, Cms: 1.17 mm/N, Bl: 3.9 N/A, Xmax: 1 mm
ARX-150-23/4
Sd: 72.4 cm2, fs: 117.1 Hz, Re: 3.53 Ohm, Qms: 3.46, Qes: 1.42, Qts: 1.01, Le: 0.13 mH,
Vas: 2.8 l, Mms: 5 g, Cms: 0.37 mm/N, Bl: 3 N/A, Xmax: 1.2 mm
ARX-150-23/8
Sd: 72.4 cm2, fs: 111.3 Hz, Re: 6.54 Ohm, Qms: 3.6, Qes: 1.76, Qts: 1.18, Le: 0.21 mH,
Vas: 2.7 l, Mms: 5.5 g, Cms: 0.37 mm/N, Bl: 3.79 N/A, Xmax: 1.5 mm
ARX-150-25/4
Sd: 72.4 cm2, fs: 101.2 Hz, Re: 3.59 Ohm, Qms: 4.41, Qes: 1.27, Qts: 0.99, Le: 0.13 mH,
Vas: 3.5 l, Mms: 5.3 g, Cms: 0.47 mm/N, Bl: 3.08 N/A, Xmax: 1.2 mm
ARX-150-25/8
Sd: 72.4 cm2, fs: 112.4 Hz, Re: 6.54 Ohm, Qms: 3.73, Qes: 1.57, Qts: 1.1, Le: 0.2 mH,
Vas: 2.8 l, Mms: 5.3 g, Cms: 0.38 mm/N, Bl: 3.94 N/A, Xmax: 1.5 mm
ARX-150-08/4
Sd: 72.4 cm2, fs: 118 Hz, Re: 3.6 Ohm, Qms: 2.66, Qes: 0.84, Qts: 0.64, Le: 0.2 mH,
Vas: 2.6 l, Mms: 5.1 g, Cms: 0.36 mm/N, Bl: 4 N/A, Xmax: 1.7 mm
ARX-150-08/8
Sd: 72.4 cm2, fs: 117.9 Hz, Re: 7.3 Ohm, Qms: 2.55, Qes: 1.33, Qts: 0.87, Le: 0.3 mH,
Vas: 2.5 l, Mms: 5.3 g, Cms: 0.34 mm/N, Bl: 4.7 N/A, Xmax: 1.4 mm
ARX-130-21/4
Sd: ? cm2, fs: ? Hz, Re: ? Ohm, Qms: ?, Qes: ?, Qts: ?, Le: ? mH,
Vas: ? l, Mms: ? g, Cms: ? mm/N, Bl: ? N/A, Xmax: ? mm
ARX-130-46/4
Sd: 72.4 cm2, fs: 107.8 Hz, Re: 3.51 Ohm, Qms: 3.09, Qes: 1.66, Qts: 1.08, Le: 0.15 mH,
Vas: 3.7 l, Mms: 4.3 g, Cms: 0.5 mm/N, Bl: 2.49 N/A, Xmax: 1.2 mm
ARX-130-46/8
Sd: 72.4 cm2, fs: 104.3 Hz, Re: 7.43 Ohm, Qms: 3.82, Qes: 2.29, Qts: 1.43, Le: 0.23 mH,
Vas: 3.6 l, Mms: 4.7 g, Cms: 0.49 mm/N, Bl: 3.18 N/A, Xmax: 1.2 mm
ARX-130-73/6
Sd: 72.4 cm2, fs: 48.4 Hz, Re: 5.35 Ohm, Qms: 2.13, Qes: 0.41, Qts: 0.34, Le: 0.39 mH,
Vas: 10.4 l, Mms: 7.6 g, Cms: 1.42 mm/N, Bl: 5.54 N/A, Xmax: 5.1 mm
ARO 464
Sd: 73.9 cm2, fs: 139.6 Hz, Re: 3.63 Ohm, Qms: 2.53, Qes: 1.75, Qts: 1.03, Le: 0.14 mH,
Vas: 4.2 l, Mms: 2.4 g, Cms: 0.55 mm/N, Bl: 2.08 N/A, Xmax: 1.9 mm
ARO 468K
Sd: 73.9 cm2, fs: 125.9 Hz, Re: 7.14 Ohm, Qms: 3.6, Qes: 2.16, Qts: 1.35, Le: 0.22 mH,
Vas: 4.9 l, Mms: 2.5 g, Cms: 0.64 mm/N, Bl: 2.55 N/A, Xmax: 1.5 mm
16,5cm / 6,5"
Citace:ARN 5614
Sd: 134.8 cm2, fs: 42.1 Hz, Re: 3.47 Ohm, Qms: 3.98, Qes: 0.49, Qts: 0.44, Le: 0.33 mH,
Vas: 30.4 l, Mms: 12 g, Cms: 1.19 mm/N, Bl: 4.73 N/A, Xmax: 7 mm
ARN 5618
Sd: 134.8 cm2, fs: 45.1 Hz, Re: 7.33 Ohm, Qms: 4.14, Qes: 0.66, Qts: 0.57, Le: 0.54 mH,
Vas: 28.9 l, Mms: 11 g, Cms: 1.13 mm/N, Bl: 5.88 N/A, Xmax: 6.4 mm
ARN 5684
Sd: 134.8 cm2, fs: 39.6 Hz, Re: 3.37 Ohm, Qms: 4.15, Qes: 0.5, Qts: 0.45, Le: 0.32 mH,
Vas: 49.9 l, Mms: 8.2 g, Cms: 1.96 mm/N, Bl: 3.71 N/A, Xmax: 7 mm
ARN 5688
Sd: 134.8 cm2, fs: 42.1 Hz, Re: 7.28 Ohm, Qms: 3.9, Qes: 0.66, Qts: 0.57, Le: 0.5 mH,
Vas: 46.2 l, Mms: 7.9 g, Cms: 1.81 mm/N, Bl: 4.8 N/A, Xmax: 6.4 mm
ARN-188-03/4
Sd: 134.8 cm2, fs: 41.7 Hz, Re: 3.5 Ohm, Qms: 4.29, Qes: 0.55, Qts: 0.49, Le: 0.35 mH,
Vas: 29.9 l, Mms: 12.4 g, Cms: 1.17 mm/N, Bl: 4.56 N/A, Xmax: 7 mm
ARN-188-03/8
Sd: 134.8 cm2, fs: 43.6 Hz, Re: 7.35 Ohm, Qms: 4.23, Qes: 0.71, Qts: 0.61, Le: 0.5 mH,
Vas: 28.6 l, Mms: 11.9 g, Cms: 1.12 mm/N, Bl: 5.8 N/A, Xmax: 6.4 mm
ARN-188-05/4
Sd: 134.8 cm2, fs: 42.1 Hz, Re: 3.46 Ohm, Qms: 4.39, Qes: 0.54, Qts: 0.48, Le: 0.35 mH,
Vas: 27.6 l, Mms: 13.2 g, Cms: 1.08 mm/N, Bl: 4.71 N/A, Xmax: 7 mm
ARN-188-05/8
Sd: 134.8 cm2, fs: 45.6 Hz, Re: 7.46 Ohm, Qms: 4.29, Qes: 0.73, Qts: 0.62, Le: 0.54 mH,
Vas: 25.5 l, Mms: 12.2 g, Cms: 1 mm/N, Bl: 5.99 N/A, Xmax: 6.4 mm
ARN-188-07/4
Sd: 137 cm2, fs: 41.9 Hz, Re: 3.5 Ohm, Qms: 3.98, Qes: 0.43, Qts: 0.38, Le: 0.3 mH,
Vas: 29.7 l, Mms: 12.8 g, Cms: 1.13 mm/N, Bl: 5.3 N/A, Xmax: 7 mm
ARN-188-07/8
Sd: 137 cm2, fs: 46.7 Hz, Re: 7.3 Ohm, Qms: 4.1, Qes: 0.62, Qts: 0.54, Le: 0.5 mH,
Vas: 23.2 l, Mms: 13.2 g, Cms: 0.88 mm/N, Bl: 6.8 N/A, Xmax: 7 mm
ARN-188-08/4
Sd: 132.7 cm2, fs: 51.1 Hz, Re: 3.52 Ohm, Qms: 3.34, Qes: 0.76, Qts: 0.62, Le: 0.37 mH,
Vas: 19 l, Mms: 12.6 g, Cms: 0.77 mm/N, Bl: 4.34 N/A, Xmax: 7 mm
ARN-188-08/8
Sd: 132.7 cm2, fs: 51 Hz, Re: 7.09 Ohm, Qms: 3.28, Qes: 0.97, Qts: 0.75, Le: 0.65 mH,
Vas: 18.8 l, Mms: 12.8 g, Cms: 0.76 mm/N, Bl: 5.48 N/A, Xmax: 6.4 mm
ARN-165-01/4
Sd: 134.8 cm2, fs: 46.4 Hz, Re: 3.45 Ohm, Qms: 3.19, Qes: 0.54, Qts: 0.46, Le: 0.31 mH,
Vas: 30.7 l, Mms: 9.8 g, Cms: 1.2 mm/N, Bl: 4.27 N/A, Xmax: 7 mm
ARN-165-01/8
Sd: 134.8 cm2, fs: 43.6 Hz, Re: 7.22 Ohm, Qms: 4.06, Qes: 0.65, Qts: 0.56, Le: 0.55 mH,
Vas: 35.2 l, Mms: 9.7 g, Cms: 1.38 mm/N, Bl: 5.44 N/A, Xmax: 6.4 mm
XW-165-1394
Sd: 134.8 cm2, fs: 44.9 Hz, Re: 3.42 Ohm, Qms: 4.29, Qes: 0.54, Qts: 0.48, Le: 0.33 mH,
Vas: 28.2 l, Mms: 11.4 g, Cms: 1.11 mm/N, Bl: 4.5 N/A, Xmax: 7 mm
XW-165-1398
Sd: 134.8 cm2, fs: 46.7 Hz, Re: 7.27 Ohm, Qms: 4.58, Qes: 0.74, Qts: 0.64, Le: 0.5 mH,
Vas: 25.7 l, Mms: 11.5 g, Cms: 1.01 mm/N, Bl: 5.78 N/A, Xmax: 6.4 mm
ARN-165-05/4
Sd: 134.8 cm2, fs: 40.7 Hz, Re: 3.49 Ohm, Qms: 3.94, Qes: 0.49, Qts: 0.44, Le: 0.34 mH,
Vas: 37.6 l, Mms: 10.4 g, Cms: 1.47 mm/N, Bl: 4.35 N/A, Xmax: 7 mm
ARN-165-05/8
Sd: 134.8 cm2, fs: 39.8 Hz, Re: 7.35 Ohm, Qms: 3.78, Qes: 0.66, Qts: 0.56, Le: 0.52 mH,
Vas: 48.9 l, Mms: 8.3 g, Cms: 1.92 mm/N, Bl: 4.84 N/A, Xmax: 6.4 mm
ARN-165-60/4
Sd: 134.8 cm2, fs: 41.7 Hz, Re: 3.5 Ohm, Qms: 3.99, Qes: 0.56, Qts: 0.49, Le: 0.33 mH,
Vas: 33.2 l, Mms: 11.2 g, Cms: 1.3 mm/N, Bl: 4.31 N/A, Xmax: 7 mm
ARN-165-60/8
Sd: 134.8 cm2, fs: 44.2 Hz, Re: 7.42 Ohm, Qms: 4.02, Qes: 0.67, Qts: 0.58, Le: 0.52 mH,
Vas: 29.6 l, Mms: 11.2 g, Cms: 1.16 mm/N, Bl: 5.85 N/A, Xmax: 6.4 mm
ARN-165-61/4
Sd: 134.8 cm2, fs: 42.3 Hz, Re: 3.4 Ohm, Qms: 3.36, Qes: 0.56, Qts: 0.48, Le: 0.32 mH,
Vas: 34.6 l, Mms: 10.5 g, Cms: 1.35 mm/N, Bl: 4.12 N/A, Xmax: 7 mm
ARN-165-61/8
Sd: 134.8 cm2, fs: 47.5 Hz, Re: 7.6 Ohm, Qms: 3.25, Qes: 0.82, Qts: 0.66, Le: 0.51 mH,
Vas: 24.8 l, Mms: 11.6 g, Cms: 0.97 mm/N, Bl: 5.66 N/A, Xmax: 6.4 mm
ARN-165-09/8
Sd: 134.8 cm2, fs: 40.2 Hz, Re: 7.22 Ohm, Qms: 5.07, Qes: 0.86, Qts: 0.74, Le: 0.56 mH,
Vas: 29.9 l, Mms: 13.4 g, Cms: 1.17 mm/N, Bl: 5.33 N/A, Xmax: 7 mm
ARO 567
Sd: ? cm2, fs: ? Hz, Re: ? Ohm, Qms: 5.3, Qes: 2.32, Qts: 1.61, Le: ? mH,
ARO 568K
Sd: ? cm2, fs: ? Hz, Re: ? Ohm, Qms: 6.54, Qes: 3, Qts: 2.06, Le: ? mH,
ARX-165-21/4
Sd: 126.7 cm2, fs: 68.4 Hz, Re: 3.6 Ohm, Qms: 2.79, Qes: 0.88, Qts: 0.67, Le: 0.3 mH,
Vas: 20 l, Mms: 6.1 g, Cms: 0.89 mm/N, Bl: 3.3 N/A, Xmax: 1.8 mm
ARX-165-22/4
Sd: 126.7 cm2, fs: 54.2 Hz, Re: 3.6 Ohm, Qms: 2.64, Qes: 0.8, Qts: 0.61, Le: 0.3 mH,
Vas: 23 l, Mms: 8.2 g, Cms: 1.02 mm/N, Bl: 3.6 N/A, Xmax: 1.8 mm
ARX-165-22/8
Sd: 126.7 cm2, fs: 60 Hz, Re: 7.6 Ohm, Qms: 2.35, Qes: 0.98, Qts: 0.7, Le: 0.6 mH,
Vas: 18 l, Mms: 8.9 g, Cms: 0.81 mm/N, Bl: 5 N/A, Xmax: 1.8 mm
ARX-168-10/4
Sd: 109.4 cm2, fs: 88.9 Hz, Re: 3.26 Ohm, Qms: 4.3, Qes: 0.95, Qts: 0.78, Le: 0.38 mH,
Vas: 6.9 l, Mms: 7.8 g, Cms: 0.41 mm/N, Bl: 3.86 N/A, Xmax: 2 mm
20cm / 8"
Citace:ARN 6614
Sd: 216.4 cm2, fs: 33.6 Hz, Re: 3.51 Ohm, Qms: 5.17, Qes: 0.67, Qts: 0.59, Le: 0.43 mH,
Vas: 89.1 l, Mms: 16.6 g, Cms: 1.35 mm/N, Bl: 4.29 N/A, Xmax: 7 mm
ARN 6618
Sd: 216.4 cm2, fs: 33.8 Hz, Re: 7.26 Ohm, Qms: 4.97, Qes: 0.83, Qts: 0.71, Le: 0.78 mH,
Vas: 76.7 l, Mms: 19 g, Cms: 1.17 mm/N, Bl: 5.93 N/A, Xmax: 6.4 mm
ARN 6684
Sd: 216.4 cm2, fs: 32.8 Hz, Re: 3.49 Ohm, Qms: 4.78, Qes: 0.68, Qts: 0.59, Le: 0.39 mH,
Vas: 76.3 l, Mms: 20.3 g, Cms: 1.16 mm/N, Bl: 4.64 N/A, Xmax: 7 mm
ARN 6688
Sd: 216.4 cm2, fs: 31.5 Hz, Re: 7.27 Ohm, Qms: 4.84, Qes: 0.82, Qts: 0.7, Le: 0.76 mH,
Vas: 84.5 l, Mms: 20.3 g, Cms: 1.25 mm/N, Bl: 5.96 N/A, Xmax: 6.4 mm
ARN-226-03/4
Sd: 216.4 cm2, fs: 33.5 Hz, Re: 3.49 Ohm, Qms: 5.06, Qes: 0.75, Qts: 0.65, Le: 0.45 mH,
Vas: 77.4 l, Mms: 19.2 g, Cms: 1.18 mm/N, Bl: 4.33 N/A, Xmax: 7 mm
ARN-226-03/8
Sd: 216.4 cm2, fs: 34.1 Hz, Re: 7.38 Ohm, Qms: 4.98, Qes: 0.88, Qts: 0.75, Le: 0.92 mH,
Vas: 72.1 l, Mms: 19.9 g, Cms: 1.1 mm/N, Bl: 5.97 N/A, Xmax: 6.4 mm
ARN-226-05/4
Sd: 216.4 cm2, fs: 33 Hz, Re: 3.53 Ohm, Qms: 5, Qes: 0.65, Qts: 0.58, Le: 0.76 mH,
Vas: 77.4 l, Mms: 19.7 g, Cms: 1.18 mm/N, Bl: 4.7 N/A, Xmax: 7 mm
ARN-226-05/8
Sd: 216.4 cm2, fs: 34.2 Hz, Re: 7.35 Ohm, Qms: 5.23, Qes: 0.88, Qts: 0.75, Le: 0.97 mH,
Vas: 71.5 l, Mms: 19.9 g, Cms: 1.09 mm/N, Bl: 5.99 N/A, Xmax: 6.4 mm
ARN-226-07/4
Sd: 216.4 cm2, fs: 34.2 Hz, Re: 3.45 Ohm, Qms: 4.44, Qes: 0.49, Qts: 0.44, Le: 1.02 mH,
Vas: 77.1 l, Mms: 18.5 g, Cms: 1.17 mm/N, Bl: 5.27 N/A, Xmax: 7 mm
ARN-226-07/8
Sd: 216.4 cm2, fs: 35.3 Hz, Re: 7.38 Ohm, Qms: 4.39, Qes: 0.66, Qts: 0.57, Le: 0.93 mH,
Vas: 73 l, Mms: 18.9 g, Cms: 1.08 mm/N, Bl: 6.86 N/A, Xmax: 6.4 mm
ARN-226-08/4
Sd: 216.4 cm2, fs: 40.2 Hz, Re: 3.45 Ohm, Qms: 3.85, Qes: 0.77, Qts: 0.64, Le: 2.39 mH,
Vas: 65.7 l, Mms: 15.7 g, Cms: 1 mm/N, Bl: 4.22 N/A, Xmax: 7 mm
ARN-226-08/8
Sd: 216.4 cm2, fs: 43.8 Hz, Re: 7.24 Ohm, Qms: 3.77, Qes: 1.01, Qts: 0.79, Le: 0.79 mH,
Vas: 53.3 l, Mms: 16.3 g, Cms: 0.81 mm/N, Bl: 5.69 N/A, Xmax: 6.4 mm
ARN-200-05/4
Sd: 216.4 cm2, fs: 32.6 Hz, Re: 3.55 Ohm, Qms: 4.72, Qes: 0.68, Qts: 0.59, Le: 0.49 mH,
Vas: 84.3 l, Mms: 18.6 g, Cms: 1.28 mm/N, Bl: 4.64 N/A, Xmax: 7 mm
ARN-200-05/8
Sd: 216.4 cm2, fs: 35 Hz, Re: 7.42 Ohm, Qms: 5.12, Qes: 0.88, Qts: 0.75, Le: 0.84 mH,
Vas: 65.8 l, Mms: 20.7 g, Cms: 1 mm/N, Bl: 6.2 N/A, Xmax: 6.4 mm
ARN-200-09/8
Sd: 216.4 cm2, fs: 32.7 Hz, Re: 7.44 Ohm, Qms: 5.02, Qes: 1.02, Qts: 0.85, Le: 0.84 mH,
Vas: 75.2 l, Mms: 20.8 g, Cms: 1.14 mm/N, Bl: 5.57 N/A, Xmax: 7 mm
ARZ 6604
Sd: 188.7 cm2, fs: 83 Hz, Re: 3.54 Ohm, Qms: 3.76, Qes: 1.26, Qts: 0.94, Le: 0.25 mH,
Vas: 21.1 l, Mms: 8.7 g, Cms: 0.42 mm/N, Bl: 3.58 N/A, Xmax: 1.7 mm
ARZ 6608
Sd: 188.7 cm2, fs: 71.4 Hz, Re: 7.54 Ohm, Qms: 3.12, Qes: 1.17, Qts: 0.85, Le: 0.45 mH,
Vas: 27 l, Mms: 9.2 g, Cms: 0.54 mm/N, Bl: 5.16 N/A, Xmax: 1.9 mm
30cm / 12"
Citace:ARN-312-00/4
Sd: 460 cm2, fs: 24.5 Hz, Re: 3.51 Ohm, Qms: 1.47, Qes: 0.38, Qts: 0.3, Le: 0.87 mH,
Vas: 263.4 l, Mms: 47.5 g, Cms: 0.89 mm/N, Bl: 8.28 N/A, Xmax: 9.5 mm
ARN-312-00/8
Sd: 460 cm2, fs: 26 Hz, Re: 7.16 Ohm, Qms: 2.06, Qes: 0.49, Qts: 0.4, Le: 1.31 mH,
Vas: 194.3 l, Mms: 57.1 g, Cms: 0.65 mm/N, Bl: 11.7 N/A, Xmax: 9.5 mm
ARA-312-00/4
Sd: 502.7 cm2, fs: 45.9 Hz, Re: 3.43 Ohm, Qms: 3.06, Qes: 0.51, Qts: 0.44, Le: 1.15 mH,
Vas: 124.9 l, Mms: 34.2 g, Cms: 0.35 mm/N, Bl: 8.14 N/A, Xmax: 1 mm
ARA-312-00/8
Sd: 502.7 cm2, fs: 44.9 Hz, Re: 6.27 Ohm, Qms: 3.09, Qes: 0.55, Qts: 0.47, Le: 1.63 mH,
Vas: 110.9 l, Mms: 40.2 g, Cms: 0.31 mm/N, Bl: 11.4 N/A, Xmax: 3.5 mm
38cm / 15"
Citace:ARA-389-00/4
Sd: 824.5 cm2, fs: 46.4 Hz, Re: 3.6 Ohm, Qms: 6.25, Qes: 0.46, Qts: 0.43, Le: 0.45 mH,
Vas: 172.7 l, Mms: 65 g, Cms: 0.18 mm/N, Bl: 12.15 N/A, Xmax: 3 mm
ARA-389-00/8
Sd: 824.5 cm2, fs: ? Hz, Re: ? Ohm, Qms: 6.93, Qes: 0.29, Qts: 0.27, Le: ? mH,
Vas: ? l, Mms: ? g, Cms: ? mm/N, Bl: ? N/A, Xmax: 3 mm
ARA-390-00/4
Sd: 824.5 cm2, fs: 29.8 Hz, Re: 3.5 Ohm, Qms: 4.28, Qes: 0.44, Qts: 0.4, Le: ? mH,
Vas: 320.1 l, Mms: 87.6 g, Cms: 0.33 mm/N, Bl: 11.4 N/A, Xmax: 5 mm
ARA-390-00/8
Sd: 824.5 cm2, fs: 29.6 Hz, Re: 6.8 Ohm, Qms: 3.3, Qes: 0.3, Qts: 0.27, Le: ? mH,
Vas: 313.1 l, Mms: 86.5 g, Cms: 0.33 mm/N, Bl: 19.1 N/A, Xmax: 5 mm
____________________________________________________________
[Image: tesla01.jpg] [Image: tesla02.jpg] [Image: tesla03.jpg] [Image: tesla04.jpg] [Image: tesla05.jpg] [Image: tesla06.jpg] [Image: tesla07.jpg] [Image: tesla08.jpg] [Image: tesla09.jpg] [Image: tesla10.jpg] [Image: tesla11.jpg] [Image: tesla12.jpg] [Image: tesla13.jpg] [Image: tesla14.jpg] [Image: tesla15.jpg]
[spoiler][Image: tesla01.jpg]
[Image: tesla15.jpg][/spoiler]
