Electrical Parameters
Re 5.62 Ohm electrical voice coil resistance at DC
Le 1.670 mH frequency independent part of voice coil inductance
L2 1.537 mH para-inductance of voice coil
R2 3.50 Ohm electrical resistance due to eddy current losses
Cmes 156 µF electrical capacitance representing moving mass
Lces 152.42 mH electrical inductance representing driver compliance
Res 62.32 Ohm resistance due to mechanical losses
fs 32.6 Hz driver resonance frequency
fm 26.9 Hz resonance frequency of driver with additional mass
Mechanical Parameters
(using add. mass)
Mms 91.641 g mechanical mass of driver diaphragm assembly including air load and voice coil
Mmd (Sd) 77.997 g mechanical mass of voice coil and diaphragm without air load
Rms 9.432 kg/s mechanical resistance of total-driver losses
Cms 0.259 mm/N mechanical compliance of driver suspension
Kms 3.86 N/mm mechanical stiffness of driver suspension
Bl 24.244 N/A force factor (Bl product)
Loss factors
Qtp 0.166 total Q-factor considering all losses
Qms 1.993 mechanical Q-factor of driver in free air considering Rms only
Qes 0.180 electrical Q-factor of driver in free air considering Re only
Qts 0.165 total Q-factor considering Re and Rms only
Vas 255.6865 l equivalent air volume of suspension
n0 4.762 % reference efficiency (2 pi-radiation using Re)
Lm 98.98 dB characteristic sound pressure level (SPL at 1m for 1W @ Re)
Lnom Zn missing dB nominal sensitivity (SPL at 1m for 1W @ Zn)
rmse Z 3.17 % root-mean-square fitting error of driver impedance Z(f)
Series resistor 0.00 Ohm resistance of series resistor
Madd 49.000 g additional mass
Sd 834.69 cm² diaphragm area
díky za ohonocení pro stabu dom subu
(using add. mass)
Loss factors
![[Image: 6413_180_l.jpg]](http://s4.postimg.cc/w16t99dq1/6413_180_l.jpg)
![[Image: 6413_90_l.jpg]](http://s4.postimg.cc/6wfsvue9l/6413_90_l.jpg)
![[Image: 6413_arm_938.jpg]](http://s4.postimg.cc/ivrb35juh/6413_arm_938.jpg)
podpoř provoz fóra
