Zdravim vsetkych. Chcel by som si postavit subwoofer s konstrukciou obsahujucou passivny radiator bola by to presne kombinacia HiVi SP 10 subwoofer a Scan speak Dicovery 26W/0-00-00 passiv. Vedel by niekto vypocitat vhodnu litraz ozvucnice...ja sam som skusal vo WinIsd ale vzdy my to vyhadzovalo nejake chybove hlasky, ktorym moc nerozumiem
Parametre su :
HiVi SP10
Nominal Impedance (Z)(Ω) : 4
Resonance Frequency (Fs)(Hz) :34
Nominal Power Handling (Pnom)(W) :500
Sensitivity (2.83v/1m)(dB) :84
Weight (M)(Kg) :13.0
VC Diameter (mm) :76 SV
DC (Re)(Ω) :3.4
VC Length (H)(mm) :46
VC Former :SV
VC Frame :AL
VC Layers :2
Magnet System
utside Ferrite
Magnet Former :Ferrite
Force Factor (BL)(N/A) :16.6
Gap Height (He)(mm) :15
Linear Excursion (Xmax)(mm) :15.5
Suspension Compliance (Cms)(uM/N) :91.4
Mechanical Q (Qms) :4.83
Electrical Q (Qes) : 0.65
Total Q (Qts) :0.57
Moving Mass (Mms)(g) :235.0
Effective Piston Area (Sd)(m2) :0.0363
Equivalent Air Volume (Vas)(L) :17.1
Cabinet Type :Sealed
Recommended Box Volume(Vb)(L) :20
-3dB Cut-Off Frequency(F3)(Hz) :43
A Scan-speak Discovery 26W/0-00
Fs 10,5 Hz
Qms 15,2
Rms 1,8 Kg/s
Mms 425g
Cms 0,55 mm/N
Sd 466cm2
Vas 170 L
Excursion +- 28mm
Parametre su :
HiVi SP10
DC (Re)(Ω) :3.4
VC Former :SV
VC Frame :AL
VC Layers :2
Magnet System
utside Ferrite Magnet Former :Ferrite
Total Q (Qts) :0.57
Fs 10,5 Hz
Qms 15,2
Rms 1,8 Kg/s
Mms 425g
Cms 0,55 mm/N
Sd 466cm2
Vas 170 L
Excursion +- 28mm
Podpoř provoz fóra
