First Watt SIT-5 - Printable Version
+--- Thread: First Watt SIT-5 (/showthread.php?tid=25420)
First Watt SIT-5 - miero - 22. 1. 2025
https://www.firstwatt.com/product/sit-5/
Citace:The SIT-5 is the most recent amplifier produced by First Watt, and is the fifth to use a Static Induction Transistor (SIT) as the power amplifying device. In 2011 we introduced our first SIT amplifier using a custom Silicon Carbide (SiC) transistor part made by SemiSouth. The amplifier also used a single power device, operating without feedback in single-ended Class A Common-Source mode to deliver 10 watts of power emulating the characteristic of a Triode, but operating at voltage and currents directly needed by loudspeakers, eliminating the output transformer.
The success of the monoblock SIT-1 led to the SIT-2, which offered similar performance at higher efficiency, and two channels in the same chassis. 2018 saw production of the SIT-3 which operated the SIT transistor in Common-Drain (follower) mode, again without feedback which was available until 2023.
Some years prior, SemiSouth suffered bankruptcy and we found ourselves unable to acquire more of this special part. However there was a company in Japan – Tokin, known for making industrial Silicon SIT parts suitable for audio use. Their production facility was destroyed in the Fukushima earthquake and tsunami, but we were able to acquire these parts from existing inventories of these devices over a period of several years. These large Tokin SITs enjoy that same Triode character, but at much higher voltage, current and power ratings than our original SITs.
Zdroj: https://www.facebook.com/PassLabs/posts/1019333850237806
First Watt SIT-5 - rvx73 - 22. 1. 2025
Možná by neškodilo, kdybys napsal, proč to sem dáváš
First Watt SIT-5 - PMA - 22. 1. 2025
rvx73 napsal:Možná by neškodilo, kdybys napsal, proč to sem dáváš
Připojuji se k dotazu.
First Watt SIT-5 - Benazi - 22. 1. 2025
Dobrý počtení.
First Watt SIT-5 - hranatybraska - 22. 1. 2025
https://www.ne.jp/asahi/evo/amp/2sk183cspp/rep.htm LOL
[Image: img_0769-png.1345345]
No dobře, pokud jde o ptákoviny, tak mám čím přispět.
https://sound-au.com/project83.htm
[Image: MOS_follower.jpg]
First Watt SIT-5 - miero - 23. 1. 2025
Pavle, neviem ci by sa dala predat tvoja skatula za $10000 :-)
Tuto este dalsie "poctenicko" a par fotodetailov k tym zosilnovacom:
- https://6moons.com/audioreview_articles/firstwatt-sit5/
Je aj toto "toy amplifier" ?
First Watt SIT-5 - Wili - 23. 1. 2025
ked na to nalepi samolepku pass a potrie hadim olejom hned to bude mat ten spravny voodoo vibe a vsetci sa z toho poseru Grin
First Watt SIT-5 - PMA - 23. 1. 2025
miero napsal:Je aj toto "toy amplifier" ?
Toy amplifiers jsou ty miniaturní čínské škatulky, které nejsou schopné dosáhnout specifikovaný výkon, při delším provozu na větší výkon se přehřívají a při výkonových špičkách se samovolně vypínají. Považuju je skutečně za hračky a nemám chuť o tom dlouze diskutovat. Pokud Ti ta koncepce vyhovuje, je to v pořádku.
Wili napsal:ked na to nalepi samolepku pass a potrie hadim olejom hned to bude mat ten spravny voodoo vibe a vsetci sa z toho poseru Grin
Jojo. Ale musel by se udělat remake, ta fotka byla pořízená v roce 2001 a už to dávno neexistuje Smile. I tehdy to byla recese, reakce na Pass Zen. Takže vlastně on-topic, reakce na Passovinu. Jen škoda, že jsem si tím zničil tu krabici na zásuvné moduly, dala by se pořád využít.
Cenu za krabicu znicenu pri vyvoji je treba zahrnut do ceny vyrobku. Ci by to stalo 200 alebo 220 tis. Kc je uz skoro jedno.
