(prohraná) bitva o decibely - Printable Version
+--- Forum: Muzika ♬ (https://www.audioweb.cz/forumdisplay.php?fid=17)
+--- Thread: (prohraná) bitva o decibely (/showthread.php?tid=13869)
Pages: 1 2 3 4 5 6
(prohraná) bitva o decibely - Zorg - 6. 9. 2013
tak nevim co me ma nasrat vic.ze posledni cd hudby praha ma DR5 a nebo to, ze jestli to empici daj na jutuub, bude ze me pornohvezna? fuuuuuuuuuu
(prohraná) bitva o decibely - redyuri - 6. 9. 2013
dr14_tmeter -f Iggy\ Pop\ And\ The\ Stooges\ Raw\ Power\ 2010/103-iggy_and_the_stooges-your_pretty_face_is_going_to_hell_\(originally_titled_hard_to_beat\).mp3
DR = 10
Peak dB = -0.27
Rms dB = -12.47
dr14_tmeter -f Raw Power 97 mix LP remaster/03 - Your Pretty Face Is Going To Hell.flac
DR = 10
Peak dB = -0.69
Rms dB = -12.34
dr14_tmeter -f Iggy\ And\ The\ Stooges-Raw\ Power/FLAC/3.\ Your\ Pretty\ Face\ Is\ Going\ To\ Hell.flac
DR = 0
Peak dB = -0.00
Rms dB = -0.79
niekde je chyba. u zdroja. posluchový rozdiel medzi posledným a prvými dvomi extrémny
(prohraná) bitva o decibely - redyuri - 29. 9. 2013
dalsi priklad, song smells like teen spirit, rozne verzie, vzdy lossless zdroj Smile
1991 - Nevermind/01 - Smells Like Teen Spirit.flac: DR 11
1991 - Nevermind (Vinyl Rip)/01 - Smells like teen spirit.flac: DR 13
1991 - Nevermind (1996 MFSL Remastering)/01 - Smells Like Teen Spirit.flac: DR 11
1996 - From The Muddy Banks Of The Wishkah/05 - Smells Like Teen Spirit.flac: DR 7
2002 - Nirvana/05 - Smells Like Teen Spirit.flac: DR 7
2004 - With The Lights Out Boxset/2004 - With The Lights Out (Disc-2)/10 - Smells Like Teen Spirit (Rehearsal Demo, 1991).flac: DR 7
2004 - With The Lights Out Boxset/2004 - With The Lights Out (Disc-2)/20 - Smells Like Teen Spirit (Butch Vig Mix - Recorded May, 1991).flac: DR 6
2005 - Sliver The Best Of The Box/13 - Smells Like Teen Spirit (Boom Box Version).flac: DR 7
6 CDs Singles Box Set/Smells Like Teen Spirit (Single)/01 - Smells Like Teen Spirit (Edit).flac: DR 11
total average DR = 9
názor si urobte sami Smile)
(prohraná) bitva o decibely - KomarD-Jeay - 29. 9. 2013
Niekto sa tu tesil, ze radia budu mat lepsi zvuk, lebo sa obmedzi hodnota MPX .... nie som si isty, ci je dovod sa tesit.
Neviem, ci ide prave o tuto hodnotu, ale maximalny modulacny vykon sa v FM radiach momentalne riadi vystupnym DSP procesorom (a udrziava na maxime), a to tak, ze sa sleduje v case amplituda vystupu a kazda dalsia vzorka sa finalne dynamicky upravi tak, aby sme v sledovanom casovom okne dosiahol blok maximalnu povolenu hodnotu. V podstate sa na zaklade stavu minulosti "predvida" buducnost.
To je info od cloveka, ktory tieto zariadenia vyraba a programuje DSP.
Ide stale o to, ako vytazit svoje frekvencne pasmo na maximum a neprekrocit povolene hodnoty presluchov na vedlajsie frekvencie.
Klasickym kompresorom to tak celkom nejde, lebo ten vraj v casovom okne obcas prekrocil povolene hodnoty a pri uzkom nastaveni a tvrdom hornom limite naopak uplne deformoval zvuk.
(prohraná) bitva o decibely - Rosak - 12. 1. 2015
Zdar pánové, dovolím si oživit toto téma.
Mám doma stále ještě svou sbírku audiokazet z doby kdy jsem studoval. Krom již zapomenutého obsahuje pár srdcovek, většinou rockových a většinou z osmdesátých let. A teď po mnoha letech jsem kazety roztřídil a pár jich poslechl. A víte co? U hodně z nich jsem naprosto nadšen jejich zvukem. V současnosti, degenerován digitalizací a empétrojkami je tohle balzám na duši (vlastně uši). A to nejen v případě, kdy originálem byla deska, ale i zvukem z tehdejších CD.
(prohraná) bitva o decibely - mechanik - 12. 1. 2015
Ja mám pocit že tento nostalgický návrat k analogu naberá až nejakeho úchylného rozmeru :-D
Pripomeniem že kazeta nasplna kvôli príliš nízkej rýchlosti pásku ani HiFi normu a kvalita zvuku je mizerná. Každý analog má daleko menší možný dynamický rozsah nez CD. Dnešné LP sú z digitálneho zdroja je tam akurát orezaná dynamika aby sa to dalo počúvať aj na LP s jeho nostalgickými "nectnosťami".
Doporučujem nepočúvať uplne komerciu a zo starších vecí ktoré sa prznia remastermi doporučujem japonské vydania silver/gold kde by mali byť zásahy minimálne. Často nahrávky majú ešte tupé výšky, sú bez basov a šumia oproti bežným remasterom. Prípadne proste nekupovať/nestahovať tie najnovšie remastery.
Pre tých pravých vinyl-istov doporučujem má výjsť nejake nové vydanie tušim Beatles z nejakych prastarých "prvotín" a bude to mono. Tiež je to na nejakom šialenom množstve LP tak je nutné to každú chvílu prehadzovať LP. Údajne to má širšiu drážku. Takže LP sa bude meniť tak po 2 skladbách určite :-D Stojí to len niekolko stoviek eur. Pardon ked som to prípadne poplietol, počul som to len mimochodom, okrajovo od velkého zberatela original CD.
(prohraná) bitva o decibely - Dohnalik - 13. 1. 2015
O to vůbec nejde, tam jde jenom o to, že ty operáky v DACech přece kurví zvuk Grin
(prohraná) bitva o decibely - Hazys - 13. 1. 2015
Dobrá muzika je na avaxhome . ws
PS: MP3ky za nic nemůžou, teda pokud nepoužíváš ty s 128k a nižším tokem. To je totiž dodrbaný ještě před tím, než se z toho ta mp3 udělá.
(prohraná) bitva o decibely - Rosak - 13. 1. 2015
Neboj, Mechaniku, žádný exorcismus digitálního démona se nekoná :-)
Třeba na mne jen dýchla nostalgie z dávno neposlouchané hudby. A třeba je to tím, že když jsem ji naposledy poslouchal, neměl jsem zdaleka tak kvalitní reprodukční zařízení a tak jsem ji nyní vlastně znovuobjevoval. Určitě se nedá celá dnešní produkce házet do jednoho pytle.
(prohraná) bitva o decibely - Pech. - 13. 1. 2015
Dohnalik napsal:O to vůbec nejde, tam jde jenom o to, že ty operáky v DACech přece kurví zvuk Grin
ten jeden nebo dva operáky v DACu jsou takovej problém, když v zesilovači je jich další hrst - ve většine komerčních je integráč i v koncáku, ne?
Hazys napsal:Dobrá muzika je na avaxhome . ws
Mno nezřídka jsem se setkal s tím, že 128kBps troska hrála líp jak 192-320kBps - vysvětlení je asi jednoduchý - někdo prostě ripnul mizernou nahrávku s nastaveným vyšším datovým tokem :-)
K tomu analogu - je mi známo, že parametry jsou ve všem horší, u LP taky... přesto si je rád poslechnu, protože se mi to tak nějak líbí, kazety ne, ty jsou zvukově strašný a nemám je rád.
(prohraná) bitva o decibely - dbmax - 16. 1. 2015
Pech. napsal:Mno nezřídka jsem se setkal s tím, že 128kBps troska hrála líp jak 192-320kBps - vysvětlení je asi jednoduchý - někdo prostě ripnul mizernou nahrávku s nastaveným vyšším datovým tokem :-)
Áno, je to pravda, v podstate to už funguje vo veľkom, veľmi často sa s tým stretávam.
