Danwatt ... - Printable Version +- Audioweb.cz (https://www.audioweb.cz) +-- Forum: Od zdroje po bedny (https://www.audioweb.cz/forumdisplay.php?fid=5) +--- Forum: Zesilovače, receivery (https://www.audioweb.cz/forumdisplay.php?fid=7) +--- Thread: Danwatt ... (/showthread.php?tid=23220) |
Danwatt ... - laco - 15. 1. 2020 strasne nemam rad ked velky kond ostane nabity, napr odide poistka, testujem bez poistky, atd uz davam vsade, hlavne do elkacov Danwatt ... - rvx73 - 15. 1. 2020 Laco, Wili - pro zajímavost: jaký používáte soft na návrh desek? Danwatt ... - Milos66 - 15. 1. 2020 Laco urcite pouziva SprintLayout. Len by ma zaujimalo naco su okolo padov tie sople z medi? Danwatt ... - laco - 15. 1. 2020 hej, sprint layout. wili eagle milos, ty si necital knihu od Selfa, ze ? zacal som to pouzivat este pred tym ako som o tom cital v tej knihevsetkym ktori pouzivaju trafopajku odporucam Danwatt ... - Milos66 - 15. 1. 2020 Tak to vysvetli aj pre nas, preco. Danwatt ... - Wili - 15. 1. 2020 ake sople? to v dnesnej dobe este niekto osadzuje dps trafopajkou? ja som ju diez dost dlhu dobu pouzival s velkym uspechom a nikdy som neznicil ziaden spoj, skor je to o komforte a dnesnej dostupnosti zbozi, preto sa cudujem.Odkedy mam TS100 ziadnu inu pajkovacku by som nechcel a to som si dost dlho myslel opak
Danwatt ... - laco - 15. 1. 2020 je to na posilnenie padov ktore nemaju "connect". uzitocne su hlavne pre prototypove dosky kde sa predpoklada viacnasobna vymena suciastok. Bear in mind that single-sided boards need thicker tracks to help ensure adhesion in case desoldering is necessary. Adding one or more ears (very short lengths of track leading nowhere) to pads with only one track running into them gives much better adhesion, and is highly recommended for the pads that are the most likely to need resoldering during maintenance, such as those for the drivers and output devices. This unfortunately is a very tedious manual task with many CAD systems, but if it is possible to define custom pad shapes, it becomes much easier. ja pouzivam bielu alebo ciernu masku pod ktorou su spoje najmenej viditelne, takze ani opticky nevadia Danwatt ... - rvx73 - 15. 1. 2020 abych tomu rozuměl - ty "uši" myslíš ty kousky cestiček např. u B a C T6 ? k tomu SprintLayoutu - jaký je, ve srovnání s Eaglem a KiCADem? Danwatt ... - laco - 15. 1. 2020 "abych tomu rozuměl - ty "uši" myslíš ty kousky cestiček např. u B a C T6 ?" ano SL je taky jednoduchy system pre nenarocne projekty. V inych som nerobil takze neviem porovnat. Danwatt ... - rvx73 - 15. 1. 2020 laco: a máš placenou verzi? A jak je na tom s knihovnami? Dají se použít ty pro Eagle? Danwatt ... - Milos66 - 15. 1. 2020 Ano, vyznam to ma pri homemade garazovych prototypkach, ale toto, co si kreslil je obojstranka s prekovmi. Tam to naopak bude vadit. Prekoveny pad s tym uchom sa bude nadmieru prehrievat. Proste je tam kus mede navyse a teda dlhsie musis drzat ten pad na teplote. A presne to co pisal Wili. Ja uz tiez nepoznam osobne nikoho kto by doma na bastlenie pouzival trafopajku. Mozno tak zaspajkovat nejaky stary kabel na povale, alebo v traktore. rvx73 knihovna je velmi jednoducho editovatelna. A ak chces za cca 30 sekund si vyrobis do knihovne novu suciastku. Danwatt ... - rvx73 - 15. 1. 2020 Miloš: pro někoho kdo to používá skoro denně, je ta editace asi v poho. Já desky dělám 3-4 za rok, a tak nechci ztrácet čas studiem manuálu jak se to dělá - nejlíp když to můžu rovnou kliknout v knihovně Do teď jsem používal KiCAD, ale tam právě mám s těmi knihovnami problém, že ne na všechno jsou k dispozici ...
Danwatt ... - laco - 15. 1. 2020 ano, uz mam platenu, 50euro nie je az tak vela ... knihovnu mam vlastnu, pouzivam relativne maly okruh suciastok (iba zosiky a podporne obvody). ked nieco chyba, pozriem dokumentaciu a dokreslim Danwatt ... - Milos66 - 15. 1. 2020 Tak ako pise Laco. Knihovna sa velmi jednoducho edituje. Dokonca je velmi jednoduche editovat suciastku na doske. Ja mam tiez vlastnu kniznicu a mam tam nanajvys mozno 200 suciastok, ktore pouzivam najcastejsie. To co chyba sa rychlo dokresli. Danwatt ... - laco - 15. 1. 2020 Milos66 napsal:Ano, vyznam to ma pri homemade garazovych prototypkach, ale toto, co si kreslil je obojstranka s prekovmi. Tam to naopak bude vadit. Prekoveny pad s tym uchom sa bude nadmieru prehrievat. Proste je tam kus mede navyse a teda dlhsie musis drzat ten pad na teplote. to je tvoj nazor, neberiem ti, imho nemas pravdu Danwatt ... - Hordek - 15. 1. 2020 Milos66:- Ja uz tiez nepoznam osobne nikoho kto by doma na bastlenie pouzival trafopajku. Já používám trafopájku stále cca 40let .... a úplně v pohodě. :-) Danwatt ... - Milos66 - 15. 1. 2020 Tak vyskusaj kvalitnu stanicu - mikropajku a potom mi napis ako to vidis. Ako vlastnim Wellerku, nic ine som do paprcky nezobral. Danwatt ... - mechanik - 15. 1. 2020 Pri trafopajke mi vyhovovalo že som ju mohol vypínať... Takže pri spájkovaní súčiastok som si mohol jednou rukou držať súčiastku s doskou a v druhej ruke som mal spájkovačku. Pri stanici keď mám v jednej ruke spájkovacie pero a v druhej cín už nemám ako držať v doske niektoré súčiastky pekne rovno... Inak trafospajkovačku som v ruke nemal asi 10-12 rokov. Danwatt ... - rvx73 - 15. 1. 2020 já mám trafopájku taky rád, dobrá je třeba na cínování silnějších lanek. Ale na pájení do desky jí používám max. na rychlé přibodování součástky (šetří to jednu ruku, jak píše mechanik), kterou pak řádně připájím mikropákou Danwatt ... - rvx73 - 16. 1. 2020 Dotaz: když dám mezi chladič a kovové pouzdro TO-3 pružnou fólii https://www.conrad.cz/teplovodiva-folie-kerafol-70-50-to-3.k189067 má cenu tam ještě patlat pastu? Jakou s tím máte zkušenost? |
