(upravil František 24. 9. 2022 19:03)
Téma: P: Nichicon 5600uF 80V, K300 a iné pekné veci :)
Minimálna objednávka 20€ + balík 4€ na SK, zásielkovňa 3€ na SK, 4€ do CZ,  platba na účet.
Treba pozrieš aj na strane 7, príspevok 123  wink
Snap-in Nichicon LLS1K562MELC  5600uF 80V  3000h 85°C
4,5€/ks
4€/ks pre 8 a viac kusov smile
https://www.mouser.sk/ProductDetail/Nic … swww%3D%3D
https://www.digikey.sk/en/products/deta … LC/2548928
Snap-in Nichicon LLS1H562MELB  5600uF 50V   3000h 85°C  30x30mm
2,8€/ks
2,4€/ks od 8 a viac kusov
https://www.mouser.sk/ProductDetail/Nic … 1AQAvD_BwE
https://www.digikey.be/en/products/deta … LB/2548876
Snap-in Nichicon LLS1E333MELC  33,000uF 25V   3000h 85°C  35x45mm
3,9€/ks
3,5€/ks od 4 a viac kusov
https://www.mouser.sk/ProductDetail/Nic … D9Jw%3D%3D
https://www.digikey.sk/en/products/deta … LC/2548856
Snap-in Nichicon LGG2C122MELC25   1200uF 160V  2000h 105°C   35x25mm
3,3€/ks
2,8€/ks od 8 a viac kusov
https://www.mouser.sk/ProductDetail/Nic … uI3w%3D%3D
https://www.digikey.sk/en/products/deta … 25/2540085
https://i.imgur.com/kr0iBaA.jpg
https://i.imgur.com/d6LqYun.jpg
https://i.imgur.com/J6pPJTJ.jpg
https://i.imgur.com/CW8a03C.jpg
Kondenzátory Nichicon UPJ1V152MHD  1500uF 35V   5000h 105°C  12,5x40mm
0,85€/ks
0,7€/ks pre 12 a viac kusov
https://www.mouser.sk/ProductDetail/Nic … 3KuQ%3D%3D
https://www.digikey.sk/en/products/deta … HD/2599311
Snap-in Nichicon LGY1J222MELZ35   2200uF 63V  5000h 105°C  22x35mm
2€/ks
1,6€/ks pre 12 a viac kusov
https://www.mouser.sk/ProductDetail/Nic … fK5Q%3D%3D
https://www.digikey.sk/en/products/deta … wCsIAugL5A
Kondenzátory Nichicon UVR1J332MRD6  3300uF 63V  2000h 85°C  25x32mm
Taká zaujímavostka smile radiálny s pitch 12,5mm, ale ide v pohode napasovať aj do 10mm pre snap-in
2€/ks
1,6€/ks pre 8 a viac kusov
https://www.mouser.sk/ProductDetail/Nic … aBHg%3D%3D
https://www.digikey.sk/en/products/deta … RD6/588873
https://i.imgur.com/HRs0hp4.jpg
https://i.imgur.com/5jagaDh.jpg
https://i.imgur.com/bUaYNxl.jpg
Nichicon LGN2Z222MELC40  2200uF 180V 3000h 105°C  35x40mm
4,5€/ks
Aktuálna cena s DPH na mouser 9,10€/ks alebo 8,10€ od 10ks
https://www.mouser.sk/ProductDetail/Nic … fARy6DY%3D
Epcos B41252B8338M  3300uF 63V 2000h 105°C   25x40mm
3€/ks
2,5€/ks pre 8 a viac kusov
https://i.imgur.com/sDPwDkH.jpg
https://i.imgur.com/TPvcVPZ.jpg
Kondenzátory Epcos - skrutkovacie svorky 6800uF 100V
3000h 105°C alebo 250.000h  40°C
Rozmery: 52x82mm - uchytenie montážným závitom.
Skrutky, podložky, matice - súčasťou balenia.
7€/ks
Posledné 4ks!
https://www.digikey.sk/en/products/deta … 00/3546033
https://www.mouser.sk/ProductDetail/EPC … AZvCEzTA==
https://i.imgur.com/oAgaK55.jpg
3R  5% 5W Wirewound  ±50ppm/°C Vishay / Dale (na obrázku v pravo)
30cent/ks  (70ks)
Cena na Mouser 1,20-1,30€/ks:
https://www.mouser.sk/ProductDetail/Vis … 8%252BlA==
https://i.imgur.com/vPTYqf4.jpg
Trafko VPP28-360  10VA 2x14V (2x19,5V naprázdno) nové s krabičkou. Posledné 2ks.
Pre pomocné obvody, ochrany, preamp, vstupné moduly atď smile
1ks - 3,5€/ks
2ks - 3€/ks
Bežná cena asi 9,5€/ks:
https://www.mouser.sk/ProductDetail/Tri … gQfOzRZQ==
https://www.digikey.sk/product-detail/e … -ND/242502
https://i.imgur.com/Ppc464k.jpg
Solid State Relay SSR Omega Engineering s chladičom na DIN lištu alebo panel.
SSRDIN600AC35 - 600Vac 35A
Ovladacie napätie 90 - 140Vac  (napr. malým trafkom alebo odporovým deličom priamo zo siete,  pre dc 4-48V doplnené optotriakom)
Nové, nepoužité s krabičkou a montážnym manuálom.
Len 9€/ks!
Podrobnejšie info:
https://www.omega.nl/pptst/SSRDIN600.html
https://i.imgur.com/M7wU9Rs.jpg
https://i.imgur.com/WtvXKot.jpg
Bezindukčné PE kondíky Panasonic Industry
Balené po 100ks.
270nF / 250Vdc 10% MPET 7.5mm
https://www.mouser.sk/datasheet/2/315/A … 947591.pdf
Excellent electrical characteristics
100ks  - 5€ (5cent/ks) nová cena 3€
100ks na Mousery 19,30€/270nF
https://www.mouser.sk/ProductDetail/Pan … ibTSXV7A==
https://i.imgur.com/HVdy3ML.jpg
https://i.imgur.com/1UHgYhh.jpg
(upravil František 9. 2. 2021 18:44)
Re: P: Nichicon 5600uF 80V, K300 a iné pekné veci :)
škoda, že nemáš na 63V, to bych ti je vytrhal z pracek...
Ja sa ozyvam, píšem SS
Nippony aj nichicony zaťial rezervované/predané...
Pridané kondenzátory Vishay Power Long Life wink
(upravil František 21. 1. 2022 20:17)
Predaných celkovo 26ks kondíkov.
Všetko so zľavou, tak aj "verejne" nová cena 2,9€/ks.
Pri väčšom množsve dohoda napr. 12ks 2,5€/ks.
Toľko stojí blbá samwha v TME wink
Ahoj kupim od teba tie 63v kond. Len musim spocitat kolko ks mi treba, pisem z mobilu az budem na PC poslem ti sz.
Ahoj.Měl bych zájem o deset kusů kondenzátorů.Jak je to s platbou do SK?
normálně, zaplatíš to jako sepa platbu z účtu, u většiny bank bezplatně. Akorát to  z mně neznámýho důvodu funguje od 8:00 do tuším 16:00 - jako by to ti úředníci zadávali ručně...
Michal si to nakoniec rozmyslel, tak zvyšné kondy zoberie Wili a bcoufal.
V podstate na teraz už nie sú.
Koncom týždňa, alebo začiatkom budúceho by mohli byť ďalšie.
Dík, dorazilo!
Pokud by byla další možnost prodeje, tak bych měl zájem o 12 ks kondenzátorů a vzal bych si k nim i nějaké nabízené 3W rezistory.
Děkuji předem za zařazení do pořadníku. Počet a hodnotu rezistorů si upřesníme pomocí SZ včetně platby a dopravy, až budou kondenzátory skladem wink
Vašek
(upravil František 5. 3. 2021 13:14)
Už to mám potvrdené, kondíky budú 100ks.
V tejto chvíli cena na farnely 169,35€ za 12ks!
https://sk.farnell.com/vishay/mal205858 … 05858682e3
12ks už zoberie Laco, 12ks markys, a 12ks eventuálne VAŠEK W.
8ks ešte dnes doobeda zobral Hippo007, prepustil som mu z mojich odložených.
Ja si odložím ešte 12ks + týchto 8ks..to je spolu 20+36ks. Tak zostáva 44ks.
Hippo007, Wili, bcoufal - balíčky odoslané.
Nové kondíky budem mať zajtra a za pôvodnú cenu.
Tak naďalej platí 2,9€/ks. Pri 12ks 2,5€/ks wink
12ks vishay kondíkov zoberie peterKa. Zostáva 32ks.
Pridané výkonové odpory HSC2001R0J  1R- 200W  TE CONNECTIVITY.
Já bych si 12ks také vzal.
Tom_L zoberie 16ks, ostali 4ks...ak bude záujem doložím z mojich do 12ks.
(upravil laco 18. 2. 2021 20:38)
tie odpory su fajn na testovanie zosikov, mam doma podobne (8R 200W). su vhodne aj na meranie skreslenia pod 0.001%
a cena je neuveritalna
