Téma: Fame Audio MS 8002 DSP
Zdravím, chci se zeptat máte nějaké zkušenosti z Fame Audio MS 8002 DSP ?
Capacity 8 Ohm
Stereo Operation
2x 550 Watts
Capacity 4 Ohm
Stereo Operation
2x 820 Watts
Capacity 8 Ohm
Bridge Operation
1640 Watts
Frequency
(Bypass)
20Hz - 20KHz -1dB
Input Sensitivity 775mV, 1.5V
Signal to Noise 96dB
THD 50% Pmax
(1KHz)
0,07%
Damping Factor
(1KHz)
>200
Crosstalk >65dB
Class H
Cooling System 2 Phase Fan
Safety Soft Start, Short Circuit, Limiter, DC Fault, AC Line Fuse, Thermal Cut
Weight 16,6Kg
