Audioweb.cz » Subwoofery, kino a sestavy » Kino Sony LBT 80 AV
Příspěvky [1]
1 ...editoval Honza321 (16. 2. 2017 8:42)
Téma: Kino Sony LBT 80 AV
Mám možnost koupit za 1000 kč  Sony LBT 80 AV  https://www.gumtree.com/p/other-stereo- … 1180789133
Samotná věž je už mimo umí pouze Pro logic ,ale co koupit nový receiver 5.1 a propojit je s reproduktory. To by mohlo docela dobře fungovat, jen nevím jestli budou na předních repro fungovat superwoofery, protože ty se na věži zapínají zvlášť
Spoiler
LBT-XB80AV
DIN power output (Rated)
FRONT SPEAKER:
100 + 100 watts
(8 ohms at 1 kHz, DIN)
CENTER SPEAKER:
35 watts
REAR SPEAKER:
17.5 + 17.5 watts
(16 ohms at 1 kHz, DIN)
Continuous RMS power output (Reference)
FRONT SPEAKER:
120 + 120 watts
(8 ohms at 1 kHz, 10%
THD)
CENTER SPEAKER:
42 watts
THD)
REAR SPEAKER:
21 + 21 watts
(16 ohms at 1 kHz, 10%
accepts impedance of 16
ohmsTHD)Specifications
Inputs
PHONO IN (phono jacks):sensitivity 3 mV,
impedance 47 kilohms
VIDEO/MD (AUDIO) IN (phono jacks):
sensitivity 250 mV,
MIX MIC (phone jack): sensitivity 1 mV,
impedance 10 kilohms
Outputs
PHONES (stereo phone jack):
accepts headphones of 8
ohms or more
VIDEO/MD (AUDIO) OUT (phono jacks):
Specifications
CD player section
System
Compact disc and digital
audio system
Laser
Semiconductor laser
(λ = 780 nm)
Emission
duration: continuous
Laser output
Max. 44.6 μ W*
* This output is the value
ohmsmeasured at a distance of
200 mm from the
objective lens surface on
the Optical Pick-up Block
with 7 mm aperture.
Wavelength
780 – 790 nm
Frequency response
2 Hz – 20 kHz (±0.5 dB)
Signal-to-noise ratio
More than 90 dB
Dynamic range
More than 90 dB
CD DIGITAL OUT
(square optical connector jack, rear panel)
Wave length:
600 nm
Output level:
–18 dBm
Příspěvky [1]
