Ahojte,
viete mi pomoct s ozvučnicou pre focal 25A1, v dokumentoch k repraku je doporučena basreflexova ozvučnica, no potreboval by som menšiu a chcel by som uzavretu, objem okolo 20-25 litrov. Bude to hrat dobre? Alebo sa mam striktne držat BR.
Parametre Reproduktora:
▼Spoiler
Nominal power 200 W
Maximum power 400 W
Sensitivity 92 dB
Cone Braided glass fi ber
Surround Butyl
Nom. impedance 4 ohms
DC resistance 3.35 ohms
VC diameter 50 mm 2 in
VC height 19 mm 3/4 in
Former Kapton®
Layers 4
Wire Copper
Inductance 1 mH
Xmax 5.5 mm 3/16 in
Magnet d x h 145 x 20 mm 5-11/16 x 13/16 in
Magnet weight 1.15 kg 2.15 Ib
Flux density 0.8 T
Gap height 8 mm 5/16 in
Net weight 3.9 kg 8.6 Ib
Fs 40.61 Hz
Vas 24.34 I
Qts 0.382
Qes 0.4
Qms 8.65
Re 3.35 ohms
Sd 339.79 cm2
Cas 1.73 E-07 m5/N
Mas 88.65 kg/m4
Ras 2614.88 ohms.ac
Cms 1.50 E-04 m/N
Mms 102.35 g
Rms 3.019 kg/s
Ces 467.95 mF
Les 32.82 mH
Res 72.44 ohms
BI 14.79 N/A
SPL 87.94 dB/W/m
Ďakujem
Skoki
